Giriş
The most common reason zippers get stuck is that dirt and debris often lodges in the zipper slider. Cleaning and lubricating your zipper helps to extend its life and prevents sticking, oxidizing, and jamming. The procedure we describe here works for both coil zippers and plastic tooth zippers. Lubricate your zipper after you’ve been in a dusty, dirty or wet environment.
Neye ihtiyacın var
Lay your garment on a table.
If you can, unzip the zipper.
Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
6 farklı kişi bu kılavuzu tamamladı.
