Ana içeriğe geç
How to Lubricate a Zipper
Neye ihtiyacın var
  1. How to Lubricate a Zipper, How to Lubricate a Zipper: adım 1, 3 resimden 1. How to Lubricate a Zipper, How to Lubricate a Zipper: adım 1, 3 resimden 2. How to Lubricate a Zipper, How to Lubricate a Zipper: adım 1, 3 resimden 3.
    • Lay your garment on a table.
    • If you can, unzip the zipper.
    • If you can't move the slider, just work around it.
    • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
  2. How to Lubricate a Zipper: adım 2, 2 resimden 1. How to Lubricate a Zipper: adım 2, 2 resimden 2.
    • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
    • Use the brush to free any dirt or debris caught inside the slider.
  3. How to Lubricate a Zipper: adım 3, 3 resimden 1. How to Lubricate a Zipper: adım 3, 3 resimden 2. How to Lubricate a Zipper: adım 3, 3 resimden 3.
    • Place a paper towel behind the zipper.
    • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
  4. How to Lubricate a Zipper: adım 4, 3 resimden 1. How to Lubricate a Zipper: adım 4, 3 resimden 2. How to Lubricate a Zipper: adım 4, 3 resimden 3.
    • Twist open the Zip Care.
    • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
    • Repeat this on both sides of the zipper teeth or coil.
  5. How to Lubricate a Zipper: adım 5, 2 resimden 1. How to Lubricate a Zipper: adım 5, 2 resimden 2.
    • Fold the paper towel over and dab any excess lubricant off the zipper.
  6. How to Lubricate a Zipper: adım 6, 2 resimden 1. How to Lubricate a Zipper: adım 6, 2 resimden 2.
    • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
Brittany McCrigler
90.430 İtibar
142 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.612 adet Kılavuz yazıldı
1Rehber Yorum
Hi Brittany, I’m hoping you have an answer for my favourite purse. The zipper is frozen due to the remnant of a plastic bag I put in my purse. Please advise!
Clair - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 72
Son 30 gün: 363
Her zaman: 119,925
