Ana içeriğe geç
How to Make a Hockey Stick Longer
Neye ihtiyacın var
  1. How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: adım 1, 2 resimden 1. How to Make a Hockey Stick Longer, How to Make a Hockey Stick Longer: adım 1, 2 resimden 2.
    • Procure an extender that will fit your stick.
    • Your stick should say if it is a junior or senior stick; get the corresponding extender.
  2. How to Make a Hockey Stick Longer: adım 2, 1 resimden 1.
    • Remove the tape on the end of the stick.
  3. How to Make a Hockey Stick Longer: adım 3, 1 resimden 1.
    • Remove the plug/stopper from the end of the stick using a spudger.
  4. How to Make a Hockey Stick Longer: adım 4, 2 resimden 1. How to Make a Hockey Stick Longer: adım 4, 2 resimden 2.
    • Heat the glue on the extender with a hair dryer for approximately four minutes.
    • The glue should look wet and sticky.
  5. How to Make a Hockey Stick Longer: adım 5, 1 resimden 1.
    • Heat the end of the stick up where you will insert the extender for about five minutes.
  6. How to Make a Hockey Stick Longer: adım 6, 3 resimden 1. How to Make a Hockey Stick Longer: adım 6, 3 resimden 2. How to Make a Hockey Stick Longer: adım 6, 3 resimden 3.
    • Insert the extender into the butt of the stick.
    • You can flip the stick and use the ground to help get the extender in all the way since it is a snug fit.
    • You can use the hair dryer as needed to heat the glue and the stick up more if you are having a hard time getting the extender in.
  7. How to Make a Hockey Stick Longer: adım 7, 1 resimden 1.
    • Wipe the excess glue where the stick and extender join with a rag or napkin.
    • Allow the glue to dry for about 10 minutes.
    • You can also go onto the next step if the stick is cooled down to normal temperature.
  8. How to Make a Hockey Stick Longer: adım 8, 2 resimden 1. How to Make a Hockey Stick Longer: adım 8, 2 resimden 2.
    • Tape the top of the stick or install grip tape (optional).
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Izzy
181 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 195
