Ana içeriğe geç
How to Make a Jeans Patch Less Noticeable
Neye ihtiyacın var
  1. How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: adım 1, 2 resimden 1. How to Make a Jeans Patch Less Noticeable, How to Make a Jeans Patch Less Noticeable: adım 1, 2 resimden 2.
    • Place the jeans on an even surface.
    • Flip your jeans inside out.
  2. How to Make a Jeans Patch Less Noticeable: adım 2, 3 resimden 1. How to Make a Jeans Patch Less Noticeable: adım 2, 3 resimden 2. How to Make a Jeans Patch Less Noticeable: adım 2, 3 resimden 3.
    • Trim any loose thread around the hole.
    • After cleaning the area, use the iron to warm the area before placing the patch.
  3. How to Make a Jeans Patch Less Noticeable: adım 3, 2 resimden 1. How to Make a Jeans Patch Less Noticeable: adım 3, 2 resimden 2.
    • Grab the patch and iron it on until it is secured to the jeans.
  4. How to Make a Jeans Patch Less Noticeable: adım 4, 3 resimden 1. How to Make a Jeans Patch Less Noticeable: adım 4, 3 resimden 2. How to Make a Jeans Patch Less Noticeable: adım 4, 3 resimden 3.
    • Start preparing your thread and needle and knot the end of the thread.
    • Push the needle from the back to the front.
    • Create an outline of the part where the patch is visible, until a circle is formed.
  5. How to Make a Jeans Patch Less Noticeable: adım 5, 3 resimden 1. How to Make a Jeans Patch Less Noticeable: adım 5, 3 resimden 2. How to Make a Jeans Patch Less Noticeable: adım 5, 3 resimden 3.
    • Push the needle from the back to the front, filling in the hole.
    • Repeat this process until the hole is covered and the patch is not showing.
    • Tie off the thread in a knot on the inside of the jeans.
  6. How to Make a Jeans Patch Less Noticeable: adım 6, 2 resimden 1. How to Make a Jeans Patch Less Noticeable: adım 6, 2 resimden 2.
    • Grabbing a new color thread, tie off a knot like mentioned in step 4.
    • Starting inside, create your desired design (we decided a moon and stars).
    • Push the needle back to front creating little clumps within the hole.
    • When you have finished the design tie it off on the inside of the jeans.
  7. How to Make a Jeans Patch Less Noticeable: adım 7, 1 resimden 1.
    • Cut a new piece of thread and place it on the inside.
    • Push the needle back to front of the jeans and push it back inside a few centimeters down.
    • Repeat this threading technique a few times, creating a star.
    • Tie off the thread on the inside of the jean.
    • Cut any excess thread from the inside of the jean.
    • Jeans are now ready to be worn.
Bitiş Çizgisi
Alejandra Gonzalez Manzo
145 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-5, Whithaus Spring 2024 UC Davis, Team 2-5, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S2G5
3 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 61
Her zaman: 552
