Ana içeriğe geç
How to Manually Eject a Stuck Disc in a PlayStation 5
Neye ihtiyacın var
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: adım 1, 3 resimden 1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: adım 1, 3 resimden 2. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: adım 1, 3 resimden 3.
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 2, 3 resimden 1. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 2, 3 resimden 2. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 2, 3 resimden 3.
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 3, 3 resimden 1. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 3, 3 resimden 2. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 3, 3 resimden 3.
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 4, 2 resimden 1. How to Manually Eject a Stuck Disc in a PlayStation 5: adım 4, 2 resimden 2.
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Jason Pinto
400 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
My Play station is different and it's a 5.
Cristine Kulkowsky - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 103
Son 30 gün: 372
Her zaman: 13,993
