Ana içeriğe geç
How to Mend Broken China
Neye ihtiyacın var
  1. How to Mend Broken China, How to Mend Broken China: adım 1, 1 resimden 1.
    • Wipe all broken edges with rubbing alcohol using a paper towel.
    • Do this to eliminate any grease and dirt.
    • Be aware that rubbing alcohol is highly flammable.
    • Be aware of sharp edges throughout this repair.
  2. How to Mend Broken China: adım 2, 1 resimden 1.
    • Pour epoxy into a smooth-surfaced container.
    • We used the plastic wrapping of the razor, but any container works.
    • Don't use epoxy in a small, confined space.
    • Do not get epoxy near eyes or on skin. Consider using polyethylene or polypropylene gloves.
  3. How to Mend Broken China: adım 3, 1 resimden 1.
    • Mix epoxy fluids with a toothpick.
    • The fluid sets in 5 minutes, so you must quickly apply it to the china. You can mix more if the first pour hardens.
  4. How to Mend Broken China: adım 4, 2 resimden 1. How to Mend Broken China: adım 4, 2 resimden 2.
    • Apply the epoxy along the edges of the base piece of china and first chipped piece of china using the toothpick.
  5. How to Mend Broken China: adım 5, 3 resimden 1. How to Mend Broken China: adım 5, 3 resimden 2. How to Mend Broken China: adım 5, 3 resimden 3.
    • Attach the first detached piece to the base carefully by hand.
    • Adjust as needed.
    • Don't worry about excess epoxy at this point. It will be removed after setting.
  6. How to Mend Broken China: adım 6, 2 resimden 1. How to Mend Broken China: adım 6, 2 resimden 2.
    • Apply epoxy on the next detached piece and the already mended piece
    • Use a tweezer to attach smaller fragments.
  7. How to Mend Broken China: adım 7, 2 resimden 1. How to Mend Broken China: adım 7, 2 resimden 2.
    • Attach the piece to the china.
    • Adjust as needed
    • Repeat the process of applying epoxy and attaching the chips until all broken pieces are successfully in place.
  8. How to Mend Broken China: adım 8, 1 resimden 1.
    • Place mended china in a container of stabilizing sand or gravel.
    • This step is performed to put the right gravitational weight on the attachments so the pieces don't become unaligned during the setting of the epoxy.
    • Leave to set for at least 1 hour.
  9. How to Mend Broken China: adım 9, 2 resimden 1. How to Mend Broken China: adım 9, 2 resimden 2.
    • Shave off as much excess epoxy as possible using the razor.
    • Exhibit caution when using the razors; they are very sharp!
  10. How to Mend Broken China: adım 10, 2 resimden 1. How to Mend Broken China: adım 10, 2 resimden 2.
    • Use coarse sandpaper to further reduce the excess epoxy.
  11. How to Mend Broken China: adım 11, 1 resimden 1.
    • Use fine sandpaper to smooth out remaining inconsistencies.
  12. How to Mend Broken China: adım 12, 2 resimden 1. How to Mend Broken China: adım 12, 2 resimden 2.
    • Darker cracks form where the clear epoxy functions as filler, but the cup will work perfectly fine! Add colored pigment to the epoxy for a more subtle repair.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Mikkeline Thomsen
141 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team S1-G4, Coad Spring 2017 UC Davis, Team S1-G4, Coad Spring 2017 üyesi
UCD-COAD-S17S1G4
3 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 12
Son 7 gün: 38
Son 30 gün: 175
Her zaman: 20,118
