Giriş
Fixing a hole in everyday garments is a necessity. Whether you are attached to your favorite blanket, simply do not want to spend money on another piece, or just love to do things yourself, mending a hole on worn fabric can be rewarding and add character.
This guide will show you how to fix fuzzy or thick blankets. The sewing process is slightly different than that of a thin-textured garment and care should be taken due to the nature of the fabric. This method will go over what tools are needed when repairing fleece blankets and give tips on how to not exaggerate the hole. The method is also intended for people who have little to no sewing experience.
Neye ihtiyacın var
After following these instructions, your blanket should be just as functional as when you first got it. The mend is not too noticeable with especially thicker blankets, but may be noticeable in your project. With time and practice, this process can be done quickly and efficiently. If you need to undo the stitching for whatever reason, use the fabric scissors to cut the knot and gently pull the stitching in reverse order.
