Giriş
Use this guide to open your Logitech G305 wireless gaming mouse.
Opening your mouse gives you access to clean its internals, troubleshoot mechanical problems, or replace a part.
Neye ihtiyacın var
Slide your mouse's power switch to the left so it's in the OFF position.
Heat an iOpener and lay it on the mouse feet for one minute to heat the adhesive.
Carefully slide the point of a spudger under one of the feet, making sure it goes under both the foot and its adhesive pad.
Gently slide the spudger farther under the foot and lift to remove it.
If the rubber layer separates from its adhesive pad, use the same process to remove the pad.
Use a spudger to carefully scrape up and remove any remaining adhesive bits.
If there's any adhesive residue left, use isopropyl alcohol and a microfiber cloth to remove it. Allow the surface to completely dry.
Remove the feet from their backing and firmly press them into place.
Press down on the top cover just above the Logitech logo and slide it back to remove it.
Use a Phillips screwdriver to remove the four 5.3 mm‑long screws securing the bottom shell.
With one hand, firmly grip the top shell.
With your free hand, insert the flat end of a spudger between the top and bottom shells near the rear of the mouse.
Slide the spudger towards the rear of the mouse while pulling the top shell up and toward the front to separate the shells.
If the shells don't separate, repeat the process on the other side of the mouse.
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Muito bom, consegui consertar o problema do botão esquerdo e ficou novinho, fiz uma limpeza e Show .
Hey, there is a little tab at the back of the mouse on step 10 that seems to be broken in this tutorial, it holds the top shell down and you have to push it backwards to release the top shell.⏎
I struggled a bit because of it, so if you are too don't force it or you might break it too, just push the tab backwards, thx!
