Giriş
Use this guide to open up and clean dust and debris out of the fan, grilles, or vents of an Xbox Series X.
If your console is loud, overheating, or underperforming, it may have built-up dust in the cooling fan, heatsink, or main vents.
In the Xbox Series X, when upright, the large top fan pulls air in from the bottom, which cools the console, then pushes the air out of the top vent. If your Xbox lives in a TV cabinet with limited airflow, consider opening the door while gaming or moving it out to open air. If your Xbox is on the ground, it may suck in extra dust, dirt, or hair and limit its ability to keep cool.
Neye ihtiyacın var
Videoya Genel Bakış
Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.5 mm pancake screw
Two 8.8 mm screws
Bu adımda kullanılan alet:Tweezers$4.99
Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
Bu adımda kullanılan alet:Dust Blower$18.99
Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
Use a small dust blower or light compressed air to blow remaining dust off of the fan.
If there's a layer of grime on the fan blades, use soapy water on a damp rag or an isopropyl alcohol wipe to clean it off.
Bu adımda kullanılan alet:Microfiber Cleaning Cloths$3.99
Use a clean rag or microfiber cloth to wipe both sides of the back panel clean.
Use a dust blower to blow out any trapped dust from both sides of the heatsink fins.
If you need to remove the heatsink for deeper cleaning, follow this guide.
Bu adımda kullanılan alet:Anti-Static Brush$2.99
Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas.
Once most dust is dislodged, use a dust blower to blow it out of the console.
Disassembly or cleaning didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
24 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Sehr geil...🤙🤙🤙🙏👍
