Ana içeriğe geç
How to Pair Replacement AirPods Pro to Airpods Pro Case
  1. How to Pair Replacement AirPods Pro to Airpods Pro Case, How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 1, 1 resimden 1.
    • Go to ‘Settings’ on your iPhone or iPad and select ‘Bluetooth.’
  2. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 2, 1 resimden 1.
    • Tap the Information icon (ⓘ) to the right of your AirPods.
  3. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 3, 1 resimden 1.
    • Tap ‘Forget This Device.’
  4. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 4, 1 resimden 1.
    • Tap ‘Forget Device’ in the first prompt, then again in the second prompt.
  5. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 5, 1 resimden 1.
    • Place the AirPods in their charging case.
  6. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 6, 1 resimden 1.
    • Check that the status light flashes amber when you open the charging case lid.
    • Reminder - The status light must flash amber when you open the case. If the status light still flashes amber, connect the case to power, close the lid, and wait 20 minutes. Then open the lid and press and hold the setup button again for a few seconds until the status light flashes white.
  7. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 7, 1 resimden 1.
    • Close the lid, then hold the setup button on the charging case until it flashes white.
  8. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 8, 1 resimden 1.
    • Go to the Home Screen on your iPhone or iPad. Open the charging case (with your AirPods inside) near your device and wait for the setup animation to appear.
  9. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 9, 1 resimden 1.
    • Tap ‘Connect,’ then ‘Done.’
    • Your AirPods don’t have to come from the exact same set to work properly. You can use two different AirPods together, provided they’re the same type or model. The same also applies when pairing AirPods with a different case.
    • Unfortunately, pairing two different AirPods isn’t always a walk in the park. That’s because the mismatched firmware makes them incompatible right off the bat. So, getting them to work correctly as a pair will require some extra steps. Here’s what to do when your replacement AirPod or AirPod Pro isn’t pairing correctly:
    • Update the AirPods’ firmware
    • As mentioned earlier, mismatched firmware is often the culprit behind AirPod pairing issues. Your old AirPod has already undergone a series of updates to improve its performance. In contrast, your replacement AirPod has none of these updates. This firmware incompatibility is what creates connection and pairing glitches.
    • Naturally, the best way to fix this is by updating the firmware of the replacement AirPod. But since there’s no option to update AirPods’ firmware manually, you’ll need to go the roundabout way. Here’s how:
    • Outdated iOS software can prevent your device from downloading new firmware updates. So, make sure to update your iOS device before attempting the procedure below.
  10. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 11, 1 resimden 1.
  11. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 12, 1 resimden 1.
  12. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 13, 1 resimden 1.
  13. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 14, 1 resimden 1.
    • Remove both AirPods from the case.
    • Take the left AirPod only and put it back in the case. The status light should flash green.
  14. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 16, 1 resimden 1.
    • Press the setup button on the case until the status light flashes white.
  15. How to Pair Replacement AirPods Pro to Airpods Pro Case: adım 17, 1 resimden 1.
    • When the setup animation appears on your device, tap ‘Connect’ to pair the left AirPod.
    • Take out the left AirPod and set it aside. Now place the right AirPod in the case and repeat steps 16 and 17.
    • If the status light still flashes amber, connect the case to power, close the lid, and wait 20 minutes. Then open the lid and press and hold the setup button again for a few seconds until the status light flashes white.
    • Is the case open?
    • Was the case fully charged?
    • Leave the Airpods in the case for an hour so that they can charge and the may connect.
Sonuç
Thank you for using this guide to pair your Airpods Pro to your Airpods Pro charging case.
Bir başkası bu kılavuzu tamamladı.
tayola
8.959 İtibar
45 adet Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
172 Üyeler
229 adet Kılavuz yazıldı
3 Yorum
It's just not working... No matter what I do, I can't make the case status light change to flash white. With the right air pod its flashing green, with the left it's red. No way seems to make the case pair with my iPhone. Altough I connected with them right before. Guess this guide needs some more information
Georg Hirsch - Yanıt
thank you for your feedback. I will see if i can update this guide. Please turn on the notify me for changes and I will be updating it shortly.
Have you updated the firmware on both of your airpods?
And did you get a new case or a new airpod?
tayola -
The case is not pairing to your iPhone? This guide only helps you pair airpods to a case. Ask your question in the answer forum to see if someone can help you.
tayola -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 63
Son 7 gün: 504
Son 30 gün: 2,207
Her zaman: 28,865
