Ana içeriğe geç
How to Patch a Hole in a Kote
Neye ihtiyacın var
  1. How to Patch a Hole in a Kote, How to Patch a Hole in a Kote: adım 1, 1 resimden 1.
    • Use the ruler to measure the hole, and add a 1/4 to 1/2 inch buffer on all sides.
  2. How to Patch a Hole in a Kote: adım 2, 1 resimden 1.
    • Use the ruler and pen to create guiding lines for these measurements directly on the backside of the leather patch.
  3. How to Patch a Hole in a Kote: adım 3, 1 resimden 1.
    • Use the scissors to cut along the guiding lines.
  4. How to Patch a Hole in a Kote: adım 4, 1 resimden 1.
    • Center the leather patch over the hole and pin it in place.
  5. How to Patch a Hole in a Kote: adım 5, 1 resimden 1.
    • Cut approximately 30 inches of thread and thread 15 inches through the needle.
    • Tie the two ends of the thread into a square knot by creating a loop, drawing the ends through the loop, and pulling it tight.
  6. How to Patch a Hole in a Kote: adım 6, 2 resimden 1. How to Patch a Hole in a Kote: adım 6, 2 resimden 2.
    • After drawing the thread through the patch from below, about 1/4 inch from the edge, use the thimble to push the needle through the kote, just outside the patch.
    • Use the pliers to pull the needle through the kote and leather.
    • Repeat the process all around the patch until you return to the first stitch.
  7. How to Patch a Hole in a Kote: adım 7, 3 resimden 1. How to Patch a Hole in a Kote: adım 7, 3 resimden 2. How to Patch a Hole in a Kote: adım 7, 3 resimden 3.
    • Knot the final stitch in place by running the needle under the first stitch.
    • Pull the thread to create a loop, and run the needle through the loop towards you.
    • To hide the knot, run the needle beneath the patch and pull the thread through, cutting it close to the patch.
  8. How to Patch a Hole in a Kote: adım 8, 1 resimden 1.
    • You have successfully patched the hole in your kote.
Sonuç
To patch your kote, follow these steps in chronological order.
Dawn Lattin
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 41
Her zaman: 1,278
