Ana içeriğe geç
How to Patch a Ripped Crotch in Cotton Pants
Neye ihtiyacın var
  1. How to Patch a Ripped Crotch in Cotton Pants, How to Patch a Ripped Crotch in Cotton Pants: adım 1, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants, How to Patch a Ripped Crotch in Cotton Pants: adım 1, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants, How to Patch a Ripped Crotch in Cotton Pants: adım 1, 3 resimden 3.
    • Place the pants in front of you with the right side facing outwards.
    • Make sure the ripped area is clean. There shouldn't be any unnecessary threads or excess fabric.
    • Measure the ripped area. It doesn't have to be an exact measurement.
  2. How to Patch a Ripped Crotch in Cotton Pants: adım 2, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 2, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants: adım 2, 3 resimden 3.
    • Choose two strips of fabric that match the color of your pants and that are twice the size of the tear in the pants.
    • For this guide, the fabric is a different color from the pants to provide better contrast.
    • Put the two strips back to back, so the inside of the fabric is facing you.
    • Connect the two pieces of fabric by putting the pin head needles on a straight line on the raw edge of the fabric.
    • The needles shouldn't be on the edge of the fabric. Put them 1 or 2 cm away from the edge.
  3. How to Patch a Ripped Crotch in Cotton Pants: adım 3, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 3, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants: adım 3, 3 resimden 3.
    • We want to temporarily connect the two pieces of fabric to each other and make a guideline so we can sew it more easily with the sewing machine.
    • Thread a hand sewing needle with a thread color that matches the pants. Make sure that you leave a large tail, about 50 cm.
    • Push the needle up through the underside of the fabric. Pull the needle up until there is some thread on the other side. Repeat until you stitch all the way down edge of the fabric.
    • Don't stitch right at the edge; leave at least half a centimeter from the stitches to the edge of the fabric.
    • The stitches don't have to be the same size.
  4. How to Patch a Ripped Crotch in Cotton Pants: adım 4, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 4, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants: adım 4, 3 resimden 3.
    • Put the fabric under the sewing machine needle. Hold both ends of the fabric with your hand, and slowly sew by pushing down the pedal.
    • Sew along the stitch line you made, about 1 cm away from the edge of the fabric.
    • After sewing all the way down, pull the hand-sewn stitches from Step 3 out of the fabric.
    • Afterwards the right side should look like the third picture.
  5. How to Patch a Ripped Crotch in Cotton Pants: adım 5, 2 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 5, 2 resimden 2.
    • Put the piece of fabric on an ironing board, with the inside of the fabric facing you.
    • Iron the piece of fabric, including the area where the two pieces of fabric are stitched together.
    • This flattens the fabric so it looks better and is easier to work with.
  6. How to Patch a Ripped Crotch in Cotton Pants: adım 6, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 6, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants: adım 6, 3 resimden 3.
    • Put the piece of fabric, facing the inside, on the ripped area. The pants should be inside out.
    • Use pin head needles to connect the fabric to the ripped area of the pants.
    • Put thread in the eye of the hand sewing needle. Make sure that you leave a large tail, about 50 cm.
    • Push the needle up through the underside of the fabric. Pull the needle up until there is some thread on the other side. Repeat until you stitch all the way around the pin head needles.
  7. How to Patch a Ripped Crotch in Cotton Pants: adım 7, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 7, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants: adım 7, 3 resimden 3.
    • Use the sewing machine to sew the fabric to the pants, using the stitches as your guide.
    • After sewing all around the pin head needles, pull the hand-sewn stitches from Step 6 out of the fabric.
  8. How to Patch a Ripped Crotch in Cotton Pants: adım 8, 3 resimden 1. How to Patch a Ripped Crotch in Cotton Pants: adım 8, 3 resimden 2. How to Patch a Ripped Crotch in Cotton Pants: adım 8, 3 resimden 3.
    • Cut the excess part of the fabric off.
    • Iron the pants on both sides.
    • This flattens the fabric and makes it look better.
  9. How to Patch a Ripped Crotch in Cotton Pants: adım 9, 1 resimden 1.
    • This is the end result.
Bitiş Çizgisi
Naseem Khaksar
169 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 33
Son 30 gün: 138
Her zaman: 8,179
