Ana içeriğe geç
How to Patch a Tear in Vinyl Furniture
Neye ihtiyacın var
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: adım 1, 1 resimden 1.
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: adım 2, 1 resimden 1.
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: adım 3, 2 resimden 1. How to Patch a Tear in Vinyl Furniture: adım 3, 2 resimden 2.
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: adım 4, 2 resimden 1. How to Patch a Tear in Vinyl Furniture: adım 4, 2 resimden 2.
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: adım 5, 1 resimden 1.
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: adım 6, 2 resimden 1. How to Patch a Tear in Vinyl Furniture: adım 6, 2 resimden 2.
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Sonuç
Once the adhesive is dry, the furniture is ready for use!
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 105
Son 30 gün: 326
Her zaman: 24,684
