Ana içeriğe geç
How to Perform an IBM ThinkPad X60s Fan Spindle Replacement
Neye ihtiyacın var
  1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement, Fan Spindle: adım 1, 1 resimden 1.
    • Turn the laptop upside-down, with the battery oriented away.
    • Slide the battery lock switch to the left.
  2. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 2, 1 resimden 1.
    • Complete these steps after disconnecting the laptop from power and after powering the laptop down.
    • Simultaneously complete the following:
    • Slide and hold the battery release switch to the right.
    • Push the battery away from you, out of the back of the laptop.
  3. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 3, 3 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 3, 3 resimden 2. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 3, 3 resimden 3.
    • Unscrew the black 4mm Phillips #2 screw securing the hard drive enclosure cover.
    • Pull the hard drive enclosure cover up and to the left to expose the hard drive caddy.
    • Pull the hard drive caddy out by the plastic pull tab.
  4. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 4, 3 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 4, 3 resimden 2. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 4, 3 resimden 3.
    • Unscrew the two black Phillips #1 screws securing the RAM cover plate.
    • These screws will remain attached to the cover plate.
    • Remove the exposed RAM sticks by prying outward (away from the edges of the RAM sticks) on the securing tabs.
  5. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 5, 1 resimden 1.
    • Unscrew the eleven black 6mm Phillips #1 screws securing the keyboard and palmrest.
    • Flip the laptop over.
  6. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 6, 2 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 6, 2 resimden 2.
    • Push the keyboard backwards (away from yourself) with both hands.
    • Pry your thumb under the mouse buttons to lift the keyboard upwards (away from the work surface).
    • Pull up to detach the keyboard ribbon tab.
  7. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 7, 2 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 7, 2 resimden 2.
    • Pull up to detach the fingerprint scanner ribbon tab.
    • Lift up on the faceplate to remove it.
  8. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 8, 2 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 8, 2 resimden 2.
    • Unscrew the five silver 3mm Phillips #1 screws securing the motherboard.
    • Unscrew the silver 7mm Phillips #1 screw securing the motherboard.
  9. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 9, 2 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 9, 2 resimden 2.
    • (Optional) Lay a piece of paper, or other protective material, over the laptop screen.
    • Flip the motherboard over onto the screen (or protective material).
    • Flipping the motherboard over should not require forceful motion.
    • Take extreme care not to damage any ribbon cables or wires still connected to the motherboard.
  10. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 10, 3 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 10, 3 resimden 2. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 10, 3 resimden 3.
    • Pry back the three metal tabs on the now-exposed underside of the fan housing with needle-nose pliers.
    • Flip the motherboard back over.
  11. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 11, 2 resimden 1. How to Perform an IBM ThinkPad X60s Fan Spindle Replacement: adım 11, 2 resimden 2.
    • Lift the metal housing off of the fan.
    • There may be foil tape securing the housing. If so, remove it carefully in order to put it back after replacing the fan spindle.
    • Remove and replace the fan spindle.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Samuel Lees
171 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S12G2
6 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 2,304
