Ana içeriğe geç
How to Prepare the Barreto Trencher E718MTH4S 2016 for Service
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
  1. How to Prepare the Barreto Trencher E718MTH4S 2016 for Service, Engage the hub lock pins: adım 1, 3 resimden 1. How to Prepare the Barreto Trencher E718MTH4S 2016 for Service, Engage the hub lock pins: adım 1, 3 resimden 2. How to Prepare the Barreto Trencher E718MTH4S 2016 for Service, Engage the hub lock pins: adım 1, 3 resimden 3.
    • Make sure that both ignition switches are turned to the off position. There is one on the engine and one on the control panel.
    • Pull the ring near one of the wheel hubs straight out, away from the wheel.
    • Rotate it so that the small roll pin lines up with its slot.
    • Release the ring so that the lock pin slides into the wheel. You may need to rotate the wheels a little before the lock pin fully engages.
    • With the pin engaged, it should be very hard to turn the wheels.
    • Repeat this step so that the lock pins on both wheels are engaged.
Sonuç
Adam O'Camb
209.768 İtibar
416 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 10
