Ana içeriğe geç
How to Propagate a Succulent Plant
Neye ihtiyacın var
  1. How to Propagate a Succulent Plant, How to Propagate a Succulent Plant: adım 1, 2 resimden 1. How to Propagate a Succulent Plant, How to Propagate a Succulent Plant: adım 1, 2 resimden 2.
    • Choose an appropriate pot for your plant.
    • Your plant should have at least an inch of space in all directions between itself and the edges of the pot. This prevents overcrowding and allows for healthy growth.
    • Be careful to avoid choosing a pot that is too big. If the plant is unable to absorb all the water in the soil, this can lead to drowning and root rot.
  2. How to Propagate a Succulent Plant: adım 2, 2 resimden 1. How to Propagate a Succulent Plant: adım 2, 2 resimden 2.
    • Cover the bottom of the new pot with a layer of small rocks.
    • Placing rocks at the bottom of the pot creates a better drainage system by providing open space between the rocks to catch excess water. This will help prevent root rot.
    • Using a pot with drainage holes can also prevent soil from being lost because it allows water to drain out.
  3. How to Propagate a Succulent Plant: adım 3, 2 resimden 1. How to Propagate a Succulent Plant: adım 3, 2 resimden 2.
    • Fill your new pot with a couple inches of potting soil. A good rule of thumb is to fill the first ⅓ of the pot.
    • Do not pack down the soil — this will make it more difficult for your plant’s roots to grow and reduce oxygen in the soil.
  4. How to Propagate a Succulent Plant: adım 4, 1 resimden 1.
    • Carefully cut off the piece of the succulent you want to propagate.
    • When cutting a branch of your succulent, cut it low on the plant so you get a long stem for your cutting.
  5. How to Propagate a Succulent Plant: adım 5, 3 resimden 1. How to Propagate a Succulent Plant: adım 5, 3 resimden 2. How to Propagate a Succulent Plant: adım 5, 3 resimden 3.
    • Gently position your cutting in its new pot.
    • Fill the pot with an appropriate amount of soil. Your plant should be close enough the top of the pot to obtain sunlight, but deep enough in the soil to be secure.
  6. How to Propagate a Succulent Plant: adım 6, 3 resimden 1. How to Propagate a Succulent Plant: adım 6, 3 resimden 2. How to Propagate a Succulent Plant: adım 6, 3 resimden 3.
    • Add a layer of soil to fill the area around your plant. You have added enough when the roots are buried and the plant can stand upright without tipping over.
    • As you fill the rest of your pot with soil, you will need to hold your plant steady with one hand. This is because the roots are not yet buried, so the insecure plant will not be able to stand on its own.
    • After you’ve added a few inches of soil, gently let go of your plant and see if it can remain upright independently.
  7. How to Propagate a Succulent Plant: adım 7, 1 resimden 1.
    • Water your plant just enough to dampen the soil around it.
    • Be careful not to overwater the plant. Succulent plants are acclimated to growing in the desert with scarce water and can easily drown if given too much water.
    • After the first watering, it is better to simply mist the soil with a spray bottle to maintain a healthy amount of moisture for your succulent. Allow the soil to dry completely before misting.
Sonuç
You may follow the steps in this process again as your plant continues to grow
Camelia Moczydlowski
145 İtibar
1 Kılavuz yazıldı
Ekip
Marist, Team S1-G2, Chaterdon Spring 2021 Marist, Team S1-G2, Chaterdon Spring 2021 üyesi
MARS-CHATERDON-S21S1G2
2 Üyeler
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 458
