Giriş
Foam camping mats can delaminate with frequent use, causing discomfort. We will show you how to re-attach the layers, ensuring your mat remains functional for future trips.
Neye ihtiyacın var
Locate the delaminated part that needs to be fixed.
Choose a suitable glue that adheres to foam surfaces.
Note: in this example, we choose a spray glue, but any foam-adapted glue will work just the same.
Place a piece of paper or old newspaper under the mat to protect the surface before spraying.
Tip: leave a distance of 20-30 cm around the mat when spraying.
Place a small piece of cardboard between the tip and the rest of the mat to prevent the spray glue from directly staining it.
Apply pressure to the area.
Note: Follow the instructions of the glue used to know the exact drying time. In this example, we waited 1 minute for the glue to dry before attaching both layers together. Afterwards, we held the parts together for 3 minutes and then let it dry overnight.
🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
