Giriş
This guide will aid in realigning door hinges. Over time door hinges can become misaligned from the weight of the door which can cause them to become harder to open/close; or they won't close at all.
With this guide, you can realign your door hinge and not have to buy new ones and replace them every few years, resulting in fewer door hinges being improperly thrown away in the garbage and ending up in landfills. Learning to repair instead of replace is a good lesson we can all put into practice more so that we can reduce worldwide waste.
Neye ihtiyacın var
Grab an unaligned door.
Either you or a person who is helping hold the door up to the desired position.
You have now successfully realigned a door hinge! Good Job
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Funciona de la misma manera para puertas con bisagras de aluminio, solo doblando los nudillos de la bisagra, excelente gracias por el contenido
