Ana içeriğe geç
How to Reassemble a Pyraminx
Neye ihtiyacın var
  1. How to Reassemble a Pyraminx, How to Reassemble a Pyraminx: adım 1, 2 resimden 1. How to Reassemble a Pyraminx, How to Reassemble a Pyraminx: adım 1, 2 resimden 2.
    • Place the pieces and core on a flat surface for easy building.
  2. How to Reassemble a Pyraminx: adım 2, 2 resimden 1. How to Reassemble a Pyraminx: adım 2, 2 resimden 2.
    • Adjust the top to a 45-degree angle and place red and green in the center of each other.
  3. How to Reassemble a Pyraminx: adım 3, 1 resimden 1.
    • Adjust the top to a 45-degree angle and place red and blue in the center of each other.
  4. How to Reassemble a Pyraminx: adım 4, 1 resimden 1.
    • Rotate the tip to 45 degrees and position the blue and green pieces so their centers line up.
  5. How to Reassemble a Pyraminx: adım 5, 3 resimden 1. How to Reassemble a Pyraminx: adım 5, 3 resimden 2. How to Reassemble a Pyraminx: adım 5, 3 resimden 3.
    • Adjust the tilt to 45 degrees and position the blue and yellow pieces so their centers line up.
    • Adjust the tilt to 45 degrees and position the blue and green pieces so that their centers line up.
    • If it's stuck, gently pry the tip in your direction. Alternatively, you could skip this step and repeat for the final two pieces. Occasionally, the screw can be easily visible by pulling off the entire tip.
  6. How to Reassemble a Pyraminx: adım 6, 3 resimden 1. How to Reassemble a Pyraminx: adım 6, 3 resimden 2. How to Reassemble a Pyraminx: adım 6, 3 resimden 3.
    • Now grab the Phillips head screwdriver and turn towards the left, just enough to loosen it for you to put the edge in. Remember, lefty loosey, righty tighty.
    • Tighten the screw to your memory after adding edges. Put back the tip pieces.
Sonuç
Thank you for exploring the Pyraminx assembly guide. I trust it helped you successfully reassemble your puzzle. Any questions, comments, or suggestions are highly valued; please share them below. Your feedback is instrumental in refining the guide for future users. Happy solving!
Bir başkası bu kılavuzu tamamladı.
gstandr
133 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 2-1, Briggs Fall 2023 CSU Los Angeles, Team 2-1, Briggs Fall 2023 üyesi
CSULA-BRIGGS-F23S2G1
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 406
