Ana içeriğe geç
How to Reassemble the Palm IIIc
Neye ihtiyacın var
  1. How to Reassemble the Palm IIIc, How to Reassemble the Palm IIIc: adım 1, 1 resimden 1.
    • Reinsert the screen into the case that contains the buttons.
  2. How to Reassemble the Palm IIIc: adım 2, 1 resimden 1.
    • Put the Motherboard back into casing from right to left.
    • Make sure the black clips are securing the motherboard into the casing.
  3. How to Reassemble the Palm IIIc: adım 3, 3 resimden 1. How to Reassemble the Palm IIIc: adım 3, 3 resimden 2. How to Reassemble the Palm IIIc: adım 3, 3 resimden 3.
    • Secure the bottom two ZIF connectors into their slots by opening the flap and inserting the ZIF connectors.
    • Gently press down on the flap to secure the ZIF connector. This secures the screen and buttons to the motherboard.
  4. How to Reassemble the Palm IIIc: adım 4, 2 resimden 1. How to Reassemble the Palm IIIc: adım 4, 2 resimden 2.
    • Connect the blue and red screen cables to the beige box they were removed from.
  5. How to Reassemble the Palm IIIc: adım 5, 2 resimden 1. How to Reassemble the Palm IIIc: adım 5, 2 resimden 2.
    • Open the ZIF connector box at the top of the motherboard by gently pulling up on the flap.
    • Insert the ZIF tab into the connector box.
    • Gently press down on the flap to secure the ZIF tab in place.
  6. How to Reassemble the Palm IIIc: adım 6, 1 resimden 1.
    • Attach the white box on the end of the red cable connected to the battery into the connector box on the motherboard.
  7. How to Reassemble the Palm IIIc: adım 7, 1 resimden 1.
    • Place the front and back covers around the casing containing the motherboard and screen.
    • Before securing the covers, place the sensor in between the front and back cover at the top of the device.
    • After the sensor is in place between the two covers, firmly secure the front and back covers.
  8. How to Reassemble the Palm IIIc: adım 8, 1 resimden 1.
    • Replace the long screws at the top of the back case with the Philips head screwdriver.
    • Replace the short screws to the bottom of the back case using the Philips head screwdriver.
    • After the screws are in place, insert the stylus.
  9. How to Reassemble the Palm IIIc: adım 9, 1 resimden 1.
    • Gently snap the flip cover back into place where it connects at the top of the Palm IIIc
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Angela Arthur
101 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-5, Buehl Winter 2012 Ohio State, Team 1-5, Buehl Winter 2012 üyesi
OSU-BUEHL-W12S1G5
5 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 320
