Ana içeriğe geç
How to Reattach Shoe Sole
Neye ihtiyacın var
  1. How to Reattach Shoe Sole, How to Reattach Shoe Sole: adım 1, 3 resimden 1. How to Reattach Shoe Sole, How to Reattach Shoe Sole: adım 1, 3 resimden 2. How to Reattach Shoe Sole, How to Reattach Shoe Sole: adım 1, 3 resimden 3.
    • Pull the separated sole away from the bottom of the shoe.
    • Clean the bottom surface of the shoe with a cleaning wipe.
  2. How to Reattach Shoe Sole: adım 2, 2 resimden 1. How to Reattach Shoe Sole: adım 2, 2 resimden 2.
    • Clean the top of the sole.
    • The shoe needs to be clean of all dirt and completely dry before continuing to the next step.
  3. How to Reattach Shoe Sole: adım 3, 3 resimden 1. How to Reattach Shoe Sole: adım 3, 3 resimden 2. How to Reattach Shoe Sole: adım 3, 3 resimden 3.
    • Apply a thin bead of glue along the top edge of the sole and across the interior surface of the sole.
    • Immediately continue to the next step after applying glue.
  4. How to Reattach Shoe Sole: adım 4, 1 resimden 1.
    • Push the sole back to its original position on the bottom of the shoe.
    • Hold the shoe and sole together for 30 seconds.
Bitiş Çizgisi
25 farklı kişi bu kılavuzu tamamladı.
Spencer Miskoviak
875 İtibar
1 Kılavuz yazıldı
Ekip
7Kılavuz Yorumları
Thank you! I have a pair of shoes of a brand i have never seen, Just love the uniqueness of them and want to make them wearable.
Francisco M. Yruegas III - Yanıt
I have not yet attempted to repair the sole separation on the completely separated soles of the lady's boots I was hoping to. I was looking for guidance here. Yet even the instructions on the glue package tell me it needs 8-12 hours of pressured curing to correctly complete this repair. So if you meant to leave the last step of this tutorial to be “Hold the shoe and sole together for 30 seconds" which is the last step available gor viewing, then at least explain the contradiction.
Stephen Carman - Yanıt
I imagine its hold for 30 seconds, the leave for 8 to 12 hours.
Stuart Cox -
Any gluing procedure almost always is more successful when clamped, weighted for at least 12 hours!
what’s the hurry? you can’t use it anyways! This includes leather, plastic, wood, fabric or whatever!
jim.
james daly - Yanıt
I would estimate a job like this a little longer. No need to rush this part, it's the most important asset to footwear. Its responsible for the function/use, comfortabilty, form, strength and durability. So this must be done efficiently and effectively.
I advise pulling apart the soles until you meet where they are joined. Starting from this point is best. Just observe the faces of the two soles and clean away any dirt and debris. Be sure to allow the footwear to dry before continuing with adhesive. Use a strong and durable adhesive to bond the two soles together. Be careful as some adhesives tend to swell after curing and this can cause discomfort and render footwear useless. Completely cover the face of both soles. Dont worry about excess just wipe away as you squeeze them together and hold. Be sure to clamp footwear soles for the duration of the curing process to prevent and leaks cracks. Then finish off with water/stain repellent to repel moisture and increase the life of the glue repair.
ChanDuhMan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 68
Son 30 gün: 317
Her zaman: 165,334
