Ana içeriğe geç
How to Reattach a Backpack Grab Handle
Neye ihtiyacın var
  1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: adım 1, 3 resimden 1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: adım 1, 3 resimden 2. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: adım 1, 3 resimden 3.
    • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
    • Caution: Be careful when using scissors this way.
  2. How to Reattach a Backpack Grab Handle: adım 2, 2 resimden 1. How to Reattach a Backpack Grab Handle: adım 2, 2 resimden 2.
    • Open up the inner seam at the same spot using a pair of scissors.
  3. How to Reattach a Backpack Grab Handle: adım 3, 2 resimden 1. How to Reattach a Backpack Grab Handle: adım 3, 2 resimden 2.
    • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
  4. How to Reattach a Backpack Grab Handle: adım 4, 3 resimden 1. How to Reattach a Backpack Grab Handle: adım 4, 3 resimden 2. How to Reattach a Backpack Grab Handle: adım 4, 3 resimden 3.
    • Thread your sewing needle.
    • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
  5. How to Reattach a Backpack Grab Handle: adım 5, 3 resimden 1. How to Reattach a Backpack Grab Handle: adım 5, 3 resimden 2. How to Reattach a Backpack Grab Handle: adım 5, 3 resimden 3.
    • Hold the edge of your grab handle down at the the first seam you opened.
    • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
    • Caution: Sewing needles are sharp; be careful not to poke yourself.
    • This repair only requires one of these two basic stitching methods.
  6. How to Reattach a Backpack Grab Handle: adım 6, 2 resimden 1. How to Reattach a Backpack Grab Handle: adım 6, 2 resimden 2.
    • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
    • Use one of these basic stitching methods.
  7. How to Reattach a Backpack Grab Handle: adım 7, 3 resimden 1. How to Reattach a Backpack Grab Handle: adım 7, 3 resimden 2. How to Reattach a Backpack Grab Handle: adım 7, 3 resimden 3.
    • Cut off the remaining thread and tie it into a knot.
Sonuç
Once you have completed this guide, you will be able to make use of your grab handle once again.
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 44
Son 30 gün: 213
Her zaman: 6,804
