Ana içeriğe geç
How to Reattach a Backpack Grab Handle
Neye ihtiyacın var
    1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: adım 1, 3 resimden 1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: adım 1, 3 resimden 2. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: adım 1, 3 resimden 3.
      • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
      • Caution: Be careful when using scissors this way.
      FixBot'a Sor
      Yorum Ekle
    2. How to Reattach a Backpack Grab Handle: adım 2, 2 resimden 1. How to Reattach a Backpack Grab Handle: adım 2, 2 resimden 2.
      • Open up the inner seam at the same spot using a pair of scissors.
      FixBot'a Sor
      Yorum Ekle
    3. How to Reattach a Backpack Grab Handle: adım 3, 2 resimden 1. How to Reattach a Backpack Grab Handle: adım 3, 2 resimden 2.
      • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
      FixBot'a Sor
      Yorum Ekle
    4. How to Reattach a Backpack Grab Handle: adım 4, 3 resimden 1. How to Reattach a Backpack Grab Handle: adım 4, 3 resimden 2. How to Reattach a Backpack Grab Handle: adım 4, 3 resimden 3.
      • Thread your sewing needle.
      • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
      FixBot'a Sor
      Yorum Ekle
    5. How to Reattach a Backpack Grab Handle: adım 5, 3 resimden 1. How to Reattach a Backpack Grab Handle: adım 5, 3 resimden 2. How to Reattach a Backpack Grab Handle: adım 5, 3 resimden 3.
      • Hold the edge of your grab handle down at the the first seam you opened.
      • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
      • Caution: Sewing needles are sharp; be careful not to poke yourself.
      • This repair only requires one of these two basic stitching methods.
      FixBot'a Sor
      Yorum Ekle
    6. How to Reattach a Backpack Grab Handle: adım 6, 2 resimden 1. How to Reattach a Backpack Grab Handle: adım 6, 2 resimden 2.
      • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
      • Use one of these basic stitching methods.
      FixBot'a Sor
      Yorum Ekle
    7. How to Reattach a Backpack Grab Handle: adım 7, 3 resimden 1. How to Reattach a Backpack Grab Handle: adım 7, 3 resimden 2. How to Reattach a Backpack Grab Handle: adım 7, 3 resimden 3.
      • Cut off the remaining thread and tie it into a knot.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Once you have completed this guide, you will be able to make use of your grab handle once again.
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 37
Son 30 gün: 187
Her zaman: 11,648
