Giriş
Use this guide if you have a broken leg on a wooden table.
Tables are the most common objects used at home or the workplace. Due to extensive use, multiple adjustments and frequent movements, table legs often get loose. Furniture is quite expensive to replace and very difficult to dispose of. This guide will illustrate basic steps to fix any kind of wooden table or chair.
Prerequisite: Before using this guide, analyze the issue and find all the broken or missing parts. Please make sure to collect all the missing screws and verify the size of the screws that are required. This guide does not require any existing knowledge to fix tables.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Carefully place the table on an even surface and identify the broken parts.
Repeat these steps to fix any other broken legs on the table.
Bir başkası bu kılavuzu tamamladı.
