Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Carefully place the table on an even surface and identify the broken parts.
Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
Remove the screws from the broken leg.
Remove the broken leg.
Use a paper towel to clean the surface of the table and legs.
Carefully apply the glue on the part that connects the table and legs.
Press the leg against the glue for few minutes.
Allow the glue to dry for at least 10 minutes.
Use an electric drill or a screwdriver to tighten the screws.
Use a paper towel to remove extra glue stains.
Allow the table to dry for 24 hours before turning the table.
After 24 hours, carefully return the table to the original position.
Depending on the size of the table, you might need some assistance to turn the table.
Bir başkası bu kılavuzu tamamladı.
