Ana içeriğe geç
How to Reattach a Cabinet's Center Stile
Neye ihtiyacın var
    1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: adım 1, 3 resimden 1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: adım 1, 3 resimden 2. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: adım 1, 3 resimden 3.
      • Measure the width and length of the detached center stile.
      FixBot'a Sor
      Yorum Ekle
    2. How to Reattach a Cabinet's Center Stile: adım 2, 3 resimden 1. How to Reattach a Cabinet's Center Stile: adım 2, 3 resimden 2. How to Reattach a Cabinet's Center Stile: adım 2, 3 resimden 3.
      • Mark the measurements on the wood block that will be the supporting piece.
      • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
      • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
      FixBot'a Sor
      Yorum Ekle
    3. How to Reattach a Cabinet's Center Stile: adım 3, 3 resimden 1. How to Reattach a Cabinet's Center Stile: adım 3, 3 resimden 2. How to Reattach a Cabinet's Center Stile: adım 3, 3 resimden 3.
      • Apply a generous amount of wood glue to one side of the wood block.
      • Spread the glue to cover the entire side of the wood.
      FixBot'a Sor
      Yorum Ekle
    4. How to Reattach a Cabinet's Center Stile: adım 4, 2 resimden 1. How to Reattach a Cabinet's Center Stile: adım 4, 2 resimden 2.
      • Place the wood piece against the back of stile and cabinet frame.
      • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
      • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
      • Remove the clamps after 24 hours.
      FixBot'a Sor
      Yorum Ekle
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 30
Son 30 gün: 118
Her zaman: 3,273
