Ana içeriğe geç
How to Reduce MacBook Pro Core Temperature
Neye ihtiyacın var
    1. How to Reduce MacBook Pro Core Temperature, Dissassembly: adım 1, 1 resimden 1.
      • First off you'll need to locate a disassembly guide for your machine and follow it carefully to remove the logic board.
      • If you haven't already, this would be a good opportunity to follow a guide for replacing the thermal paste.
      FixBot'a Sor
      Yorum Ekle
    2. How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: adım 2, 3 resimden 1. How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: adım 2, 3 resimden 2. How to Reduce MacBook Pro Core Temperature, Thermally bonding the heatsinks: adım 2, 3 resimden 3.
      • The aim here is to sandwich thick thermal pads under you MacBook's heatsinks to contact the upper case, and atop them to contact the bottom cover. This will help conduct heat away from the machine by effectively making the entire unibody one big heatsink.
      • On my machine, a mid-2010 15 inch MBP, I needed to use three strips of a 2mm thick thermal pad under the centre heatsink, two strips under the side one and one strip atop each to make contact with the bottom cover.
      • Try to use enough layers that the heatsinks are in good contact, but not so many that anything needs to bend to fit back.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Now reassemble your MacBook by following the disassembly guide in reverse-order. Always monitor your system's temperatures before running any heavy applications just in case something went wrong.
18 farklı kişi bu kılavuzu tamamladı.
Dan
2.463 İtibar
3 adet Kılavuz yazıldı
1Rehber Yorum
This ist crazy.
Went from 55 idle to 30 idle and a top end of 83°c instead of throttling.
(13” retina macbook pro)
Peter Nemeth - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 105
Her zaman: 18,025
