Ana içeriğe geç
How to Refinish Wood Furniture
Neye ihtiyacın var
  1. How to Refinish Wood Furniture, How to Refinish Wood Furniture: adım 1, 2 resimden 1. How to Refinish Wood Furniture, How to Refinish Wood Furniture: adım 1, 2 resimden 2.
    • Remove all hardware from the furniture.
  2. How to Refinish Wood Furniture: adım 2, 1 resimden 1.
    • Next you will need to wash any grease or contaminations before sanding.
    • Washing your furniture prior to sanding will prevent dirt, grease, and contaminations from being sanded into the surface of the furniture.
  3. How to Refinish Wood Furniture: adım 3, 1 resimden 1.
    • After the surface is dry begin sanding.
    • Remember to only sand with the grain so the sanding scratches will blend in with the grain.
  4. How to Refinish Wood Furniture: adım 4, 1 resimden 1.
    • Spray or paint on your primer prior to painting.
    • Remember if using spray paint to apply in a sweeping motion.
  5. How to Refinish Wood Furniture: adım 5, 1 resimden 1.
    • After allowing primer to dry approximately 3 hours apply paint. Allow paint 24 hours to dry.
    • If you are able to see the primer mixed in the paint, you may need to apply second coat of paint if needed.
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 153
