Ana içeriğe geç
How to Reinsert a Wooden Chair Side Stretcher
Neye ihtiyacın var
  1. How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: adım 1, 2 resimden 1. How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: adım 1, 2 resimden 2.
    • Use the sandpaper to rough up the empty dowel holes on the side stretcher and the chairs legs.
  2. How to Reinsert a Wooden Chair Side Stretcher: adım 2, 2 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 2, 2 resimden 2.
    • Check if the new dowel fits through the stretcher hole and the leg hole.
  3. How to Reinsert a Wooden Chair Side Stretcher: adım 3, 3 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 3, 3 resimden 2. How to Reinsert a Wooden Chair Side Stretcher: adım 3, 3 resimden 3.
    • Using the disposable stirrer and bowl, mix a 2:1 ratio of sawdust and wood glue.
    • The final consistency should be paste-like.
  4. How to Reinsert a Wooden Chair Side Stretcher: adım 4, 3 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 4, 3 resimden 2. How to Reinsert a Wooden Chair Side Stretcher: adım 4, 3 resimden 3.
    • With the stirrer, fill in the leg hole of the broken dowel with the paste.
  5. How to Reinsert a Wooden Chair Side Stretcher: adım 5, 2 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 5, 2 resimden 2.
    • Apply a glob of wood glue to the other leg's hole.
    • Use the stirrer to spread the glue around the hole.
  6. How to Reinsert a Wooden Chair Side Stretcher: adım 6, 2 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 6, 2 resimden 2.
    • Insert the intact stretcher dowel into the leg hole with wood glue.
  7. How to Reinsert a Wooden Chair Side Stretcher: adım 7, 2 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 7, 2 resimden 2.
    • Align the empty stretcher hole to the the leg hole filled with paste.
    • Insert the dowel and firmly push it in till it's fully submerged into the stretcher hole.
    • Insertion of the dowel will push out some of the wood paste.
  8. How to Reinsert a Wooden Chair Side Stretcher: adım 8, 2 resimden 1. How to Reinsert a Wooden Chair Side Stretcher: adım 8, 2 resimden 2.
    • Put the legs holding the stretcher between the bar clamp's jaws.
    • Screw in the handle to clamp together the legs until it is secure.
    • Putting a cloth or barrier between the clamp and the leg can prevent possible damage to the wood's surface.
  9. How to Reinsert a Wooden Chair Side Stretcher: adım 9, 1 resimden 1.
    • Remove any wood glue or paste residue on the legs and stretcher with a damp paper towel.
  10. How to Reinsert a Wooden Chair Side Stretcher: adım 10, 1 resimden 1.
    • Leave the chair and bar clamp in place for 24 hours while the wood glue and paste cures.
    • After waiting, screw out the clamp's handle to remove it from the chair.
Sonuç
Your chair should now resemble how it was before, with the side stretcher back in place. Happy fixing!
Bir başkası bu kılavuzu tamamladı.
Shaelyn
205 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-6, Andersen Winter 2024 UC Davis, Team 3-6, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S3G6
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 496
