Giriş
This guide will help with the process of Re-keying a Deadbolt Lock in your door. For purposes of clarity, this guide has the deadbolt out of the door so each part can be seen with as much detail as possible. Re-keying a lock is useful for improving the security of a home and it can replace previous keys that you have lost or may have been unknowingly copied. Many steps of this process contain small parts, so proceed with caution in this fix.
Note: This re-keying was performed on a Kwikset deadbolt, but the procedure should be the same for most brands.
Remove the mounting screws from the thumb-turn side of the lock assembly using a Phillips screwdriver.
To reassemble your device, follow these instructions in reverse order from step 8.
13 farklı kişi bu kılavuzu tamamladı.
