Giriş
If you have a Sony VO or VP series U-Matic player that goes into standby when you try to stop or eject a tape, the pinch lever may be stuck. This guide will show you how to release it and prevent it from getting stuck again.
First, remove the top cover. It is held on by four screws, one in each corner. (This varies by model)
Next, remove the indicated end of this spring and the E-clip. A pair of curved tweezers can be handy for the spring.
Slide the pinch lever partway up its shaft, and try to get some oil inside the bushing at the bottom of the capstan lock.
I used common bike chain oil on my machine and it has been working well for about a year as of writing this. I doubt this is the best oil to use though, so if you have something better, go for it.
That's it! Assuming all other functions work, you now have a working U-Matic player.
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
Thanks, it worked for me! I used 3 in 1 machine oil. I had a VO-7600 with the same issue, it would not unthread and go into standby when you tried to eject or stop playing a tape.
