Ana içeriğe geç
How to Remove Calcium Buildup from a Shower Head
Neye ihtiyacın var
  1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: adım 1, 2 resimden 1. How to Remove Calcium Buildup from a Shower Head, How to Remove Calcium Buildup from a Shower Head: adım 1, 2 resimden 2.
    • Using an adjustable wrench, loosen the bolt that attaches the shower head to the wall spout by turning the wrench counterclockwise.
    • You may be able to loosen the shower head by hand.
    • Handle carefully because the shower head may be heavy.
  2. How to Remove Calcium Buildup from a Shower Head: adım 2, 1 resimden 1.
    • Use your hands to finish unscrewing the bolt.
    • Remove the shower head from the wall spout.
  3. How to Remove Calcium Buildup from a Shower Head: adım 3, 3 resimden 1. How to Remove Calcium Buildup from a Shower Head: adım 3, 3 resimden 2. How to Remove Calcium Buildup from a Shower Head: adım 3, 3 resimden 3.
    • Pour one cup of water into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the water.
  4. How to Remove Calcium Buildup from a Shower Head: adım 4, 3 resimden 1. How to Remove Calcium Buildup from a Shower Head: adım 4, 3 resimden 2. How to Remove Calcium Buildup from a Shower Head: adım 4, 3 resimden 3.
    • Pour one cup of distilled vinegar into the plastic bag.
    • Completing this step over a sink may help to avoid spilling the solution.
    • If using the vinegar solution provided in steps 3 and 4 fails to provide adequate results, you may want to repeat the steps using CLR (Calcium, Lime, and Rust) solution instead.
  5. How to Remove Calcium Buildup from a Shower Head: adım 5, 2 resimden 1. How to Remove Calcium Buildup from a Shower Head: adım 5, 2 resimden 2.
    • Place the shower head face down into the plastic bag of vinegar solution.
    • Let the shower head sit for one hour before removing it from the plastic bag of vinegar solution.
  6. How to Remove Calcium Buildup from a Shower Head: adım 6, 1 resimden 1.
    • After one hour, remove the shower head from the plastic bag of vinegar solution.
    • Use a metal sponge to scrub in a circular motion to remove the treated calcium on the shower head.
    • Excessive scrubbing could damage the finish.
  7. How to Remove Calcium Buildup from a Shower Head: adım 7, 2 resimden 1. How to Remove Calcium Buildup from a Shower Head: adım 7, 2 resimden 2.
    • Place the shower head under running water to remove any extra calcium left behind.
    • If calcium is still present, repeat steps 5 through 7 as needed.
  8. How to Remove Calcium Buildup from a Shower Head: adım 8, 2 resimden 1. How to Remove Calcium Buildup from a Shower Head: adım 8, 2 resimden 2.
    • Clamp the adjustable wrench onto the bolt of the shower head.
    • Turn the adjustable wrench clockwise to tighten the shower head back onto the water spout.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Jacob Abrego
150 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 26-6, Rauch Spring 2016 Texas Tech, Team 26-6, Rauch Spring 2016 üyesi
TTU-RAUCH-S16S26G6
3 Üyeler
4 adet Kılavuz yazıldı
1Rehber Yorum
How to remove rust stain (from iron) from bathroom tiles?
waihong yeung - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 46
Her zaman: 10,406
