Ana içeriğe geç
How to Remove Carbon Buildup In A 2012 Volkswagon CC
Neye ihtiyacın var
  1. How to Remove Carbon Buildup In A 2012 Volkswagon CC, How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 1, 2 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC, How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 1, 2 resimden 2.
    • Start the engine.
    • Let the engine warm up to operating temperature.
    • Shut the engine off.
  2. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 2, 3 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 2, 3 resimden 2. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 2, 3 resimden 3.
    • Locate the hood latch lever under the left side of the dash on the driver side of the vehicle.
    • Pull the hood latch lever towards the rear of the vehicle to unlock the hood.
    • Apply upward pressure on the front of the hood and pull up on the plastic lever that is under the front center section of the hood.
  3. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 3, 2 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 3, 2 resimden 2.
    • Find the engine air intake hose near the top rear of the engine bay.
    • The opening clip can be found near the joint of the intake hose.
    • Make sure this clip is located after the Mass Airflow Sensor in order to avoid a check engine light.
    • The engine may be hot to the touch.
  4. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 4, 2 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 4, 2 resimden 2.
    • Hang the intake cleaner can in the engine bay for easy access and use in the future steps.
    • Remove the line from the packaging.
  5. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 5, 2 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 5, 2 resimden 2.
    • Apply pressure on the tabs of the metal clip with the pliers to release the pressure from the intake hose.
    • Slide the clip to the left so that it does not cover the joint.
    • The clip is very strong, so a large amount of force may be required.
  6. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 6, 1 resimden 1.
    • Separate the hose connection by applying a twisting and pulling force simultaneously on both ends of the connection.
  7. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 7, 3 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 7, 3 resimden 2. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 7, 3 resimden 3.
    • Insert the metal hook at the end of the valve cleaner line into hose opening.
    • Close the intake hose over the hook being sure not to pinch the part of the line that is not covered by the hook.
    • Secure the intake hose so that a moderately tight seal keeps the valve cleaner line secure.
  8. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 8, 1 resimden 1.
    • Guide the extra cleaner line through the metal hook so that it extends into the intake hose.
  9. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 9, 1 resimden 1.
    • Turn the red dial for the cleaner timer from the "O" to the “I” position.
  10. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 10, 1 resimden 1.
    • This step will start the timer on the can. You will have 1 minute before the can starts dispensing the cleaner. Be ready to complete step 11 and start step 12 in this time frame.
    • Arm the spring in the can by turning the blue dial from "O" to “I".
    • Assure the can is secure so that it will not interfere with the engine or fall off the hanger.
  11. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 11, 2 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 11, 2 resimden 2.
    • Return to the interior of the vehicle.
    • Assure the vehicle is in neutral and the parking brake is set to prevent inadvertent vehicle movement.
    • Start the vehicle within one minute of arming the valve cleaner can.
  12. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 12, 2 resimden 1. How to Remove Carbon Buildup In A 2012 Volkswagon CC: adım 12, 2 resimden 2.
    • Press the accelerator and bring the engine up to 3x idle speed.
    • For this make and model the speed will read 2800 RPM.
    • Hold the engine at this speed for 9-10 minutes until the cleaner is completely empty.
    • Shut off the engine.
Sonuç
To reassemble your vehicle, follow these instructions from step 6 to step 2 in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 1,831
