Ana içeriğe geç
How to Remove Cutting Board Scratches
Neye ihtiyacın var
  1. How to Remove Cutting Board Scratches, How to Remove Cutting Board Scratches: adım 1, 1 resimden 1.
    • Thoroughly wash the cutting board with warm water and gentle dish soap.
    • Rinse the cutting board to make sure all the soap is removed.
  2. How to Remove Cutting Board Scratches: adım 2, 1 resimden 1.
    • Pat the cutting board dry with a towel.
    • Allow the cutting board to completely air dry.
  3. How to Remove Cutting Board Scratches: adım 3, 1 resimden 1.
    • Use a fine grit sandpaper (220-grit) and gently sand the scratched sections of the board.
    • Use even pressure until the scratches disappear.
  4. How to Remove Cutting Board Scratches: adım 4, 1 resimden 1.
    • Remove any dust or residue using a damp towel.
    • Make sure the cutting board is completely clean and dry before moving on to the next step.
  5. How to Remove Cutting Board Scratches: adım 5, 1 resimden 1.
    • Pour a generous amount of food-safe oil onto the surface of the board.
    • The amount will vary depending on the size of the board.
    • Allow the oil to soak into the cutting board overnight.
    • Wipe off any excess oil.
    • If there are still scratches visible on the cutting board, repeat all steps if necessary.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 13
Son 30 gün: 52
Her zaman: 452
