Ana içeriğe geç
How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC
Neye ihtiyacın var
  1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC, How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 1, 1 resimden 1.
    • Unplug the humidifier from the wall.
  2. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 2, 2 resimden 1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 2, 2 resimden 2.
    • Pour out any remaining water from the water tank into the sink.
    • Pour out any remaining water from the water base into the sink.
  3. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 3, 3 resimden 1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 3, 3 resimden 2. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 3, 3 resimden 3.
    • Using a measuring cup, fill up the base of the humidifier with 1 cup of distilled white vinegar (250 mL).
    • Leave the solution of vinegar in the base for 30-40 minutes.
    • The vinegar will start making a soft sizzling/bubbling sound which is perfectly fine because it means the solution is doing its work.
    • Keep an eye on the solution as you proceed with the other steps.
  4. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 4, 3 resimden 1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 4, 3 resimden 2. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 4, 3 resimden 3.
    • Using the same measuring cup, fill up the water tank with 2 cups of distilled white vinegar (500 mL).
    • Seal the water tank shut and give it a good shake for 1-2 minutes so the vinegar can be spread throughout.
    • Once again, if the vinegar makes a soft sizzling/bubbling sound, it is perfectly okay.
  5. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 5, 3 resimden 1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 5, 3 resimden 2. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 5, 3 resimden 3.
    • Push the nozzle located at the bottom of the water tank so the vinegar slowly filters through it and into the sink.
    • Ensure that the humidifier is facing upward as shown in the third picture so the vinegar can slowly pass through the nozzle.
  6. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 6, 3 resimden 1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 6, 3 resimden 2. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 6, 3 resimden 3.
    • Using a different measuring cup, fill up the water tank with 2 cups of water (500 mL) to rinse it of any vinegar still left inside.
    • Seal the water tank shut and give it a good shake for 1-2 minutes.
  7. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 7, 1 resimden 1.
    • Pour out the water from the water tank into the sink.
  8. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 8, 1 resimden 1.
    • Using a small soft brush, scrub the inside of the water tank to remove any hard water residue left inside.
    • This guide uses a tooth brush to scrub the inside of the water tank, but any small soft brush will work.
  9. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 9, 1 resimden 1.
    • Pour out the solution of vinegar from the base into the sink after 30-40 minutes has passed.
  10. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 10, 2 resimden 1. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 10, 2 resimden 2.
    • Using a dry paper towel, wipe off all the hard water residue that is left on the base.
  11. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 11, 1 resimden 1.
    • Let the water tank and base air dry for 1 hour.
  12. How to Remove Hard Water Build-up from a Vicks Mini Cool Mist Ultrasonic VUL520WC: adım 12, 1 resimden 1.
    • Add water to the water tank and turn the humidifier on to ensure that mist is being emitted again.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 1,842
