Ana içeriğe geç
How to Remove Scratches from a Car's Interior
Neye ihtiyacın var
  1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: adım 1, 2 resimden 1. How to Remove Scratches from a Car's Interior, How to Remove Scratches from a Car's Interior: adım 1, 2 resimden 2.
    • Clean the area around the scratch with the interior cleaner.
    • By removing the dirt, you will keep the debris from melting into the plastic and it will result in a smooth finish.
  2. How to Remove Scratches from a Car's Interior: adım 2, 2 resimden 1. How to Remove Scratches from a Car's Interior: adım 2, 2 resimden 2.
    • Using the heat gun, gently apply heat to the plastic until it begins to soften.
    • Don't leave it on too long or else the plastic will burn and warp.
    • The plastic is ready for molding when it loses its texture and becomes slightly glossy.
  3. How to Remove Scratches from a Car's Interior: adım 3, 1 resimden 1.
    • Apply the grain pad to the intended area using light pressure.
    • This should smooth out the scratch and will give a textured finish that will blend in with the rest of the panel.
    • Make sure you use a grain pad that closely resembles the trim of your car.
  4. How to Remove Scratches from a Car's Interior: adım 4, 1 resimden 1.
    • Let the area cool and harden.
    • The texture should now look similar to the unaffected area.
  5. How to Remove Scratches from a Car's Interior: adım 5, 1 resimden 1.
    • Use a super- fine grain sandpaper to sand out the area, making it smooth and authentic looking.
  6. How to Remove Scratches from a Car's Interior: adım 6, 1 resimden 1.
    • Clean and dry the area again using the same method as in step 1 (the interior cleaner) and you're done!
Sonuç
By following these steps you will be able to remove scratches from your cars interior.
2 Yorum
what brand of grain pads do you recommend? having a difficult time finding them onlinw
Ron Beyer - Yanıt
Any luck finding “grain texture” pads?
ChrisB - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 103
Son 7 gün: 919
Son 30 gün: 4,559
Her zaman: 79,023
