Ana içeriğe geç
How to Remove a Blood Stain from Satin
Neye ihtiyacın var
  1. How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: adım 1, 2 resimden 1. How to Remove a Blood Stain from Satin, How to Remove a Blood Stain from Satin: adım 1, 2 resimden 2.
    • Dip the stained fabric in bowl of cold water.
    • Massage the stain while submerged for about 20 seconds to ensure that it is fully saturated.
  2. How to Remove a Blood Stain from Satin: adım 2, 1 resimden 1.
    • Pour laundry detergent or dish soap into bowl.
    • Amount poured should equate to approximately 1/2 cup (120ml). Larger stains may require higher quantities.
  3. How to Remove a Blood Stain from Satin: adım 3, 2 resimden 1. How to Remove a Blood Stain from Satin: adım 3, 2 resimden 2.
    • Wet a clean, dry cloth or sponge in the bowl.
  4. How to Remove a Blood Stain from Satin: adım 4, 2 resimden 1. How to Remove a Blood Stain from Satin: adım 4, 2 resimden 2.
    • Dab the stain gently by repeatedly pressing the wet cloth or sponge against it.
    • Rubbing the stain may further spread it and/or embed it deeper in the fabric.
  5. How to Remove a Blood Stain from Satin: adım 5, 2 resimden 1. How to Remove a Blood Stain from Satin: adım 5, 2 resimden 2.
    • Rinse the stain with cold water.
    • Inspect to determine whether further cleaning is required.
  6. How to Remove a Blood Stain from Satin: adım 6, 1 resimden 1.
    • Add a few drops of vinegar or hydrogen peroxide to the initial solution if the stain persists.
    • Repeat steps 3 and 4.
    • The combination of these chemicals creates peracetic acid. Do not mix hydrogen peroxide and vinegar.
  7. How to Remove a Blood Stain from Satin: adım 7, 1 resimden 1.
    • Rinse the garment in a bowl of clean water.
Sonuç
Repeat as needed until the stain is gone.
Malak Elsayed Elghobashy
145 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team 1-1, Morris Winter 2025 York University, Team 1-1, Morris Winter 2025 üyesi
YORK-MORRIS-W25S1G1
5 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 87
Her zaman: 539
