Ana içeriğe geç
How to Remove a Broken and Embedded Screw
Neye ihtiyacın var
  1. How to Remove a Broken and Embedded Screw, How to Remove a Broken and Embedded Screw: adım 1, 1 resimden 1.
    • Use an angle grinder to grind the tip of the broken screw until its surface is smooth and even.
    FixBot'a Sor
    Yorum Ekle
  2. How to Remove a Broken and Embedded Screw: adım 2, 2 resimden 1. How to Remove a Broken and Embedded Screw: adım 2, 2 resimden 2.
    • Place a center punch in the middle of the tip of the screw.
    • Use a hammer to hit the center punch to make a dent in the center of the embedded screw.
    FixBot'a Sor
    Yorum Ekle
  3. How to Remove a Broken and Embedded Screw: adım 3, 3 resimden 1. How to Remove a Broken and Embedded Screw: adım 3, 3 resimden 2. How to Remove a Broken and Embedded Screw: adım 3, 3 resimden 3.
    • Place a center drill bit in the dent made in the previous step and start drilling until it expands enough to fit the standard drill bit inside it.
    • Always keep the drill bit at a 90 degree angle to the surface of the screw since tilting it can bend and break its tip.
    FixBot'a Sor
    Yorum Ekle
  4. How to Remove a Broken and Embedded Screw: adım 4, 3 resimden 1. How to Remove a Broken and Embedded Screw: adım 4, 3 resimden 2. How to Remove a Broken and Embedded Screw: adım 4, 3 resimden 3.
    • Make a hole in the tip of the screw by drilling with a standard drill bit.
    • Keep drilling until the hole reaches near the end of the screw.
    FixBot'a Sor
    Yorum Ekle
  5. How to Remove a Broken and Embedded Screw: adım 5, 2 resimden 1. How to Remove a Broken and Embedded Screw: adım 5, 2 resimden 2.
    • Insert a screw extractor in the hole and then hammer it inside, making sure it is tight.
    FixBot'a Sor
    Yorum Ekle
  6. How to Remove a Broken and Embedded Screw: adım 6, 3 resimden 1. How to Remove a Broken and Embedded Screw: adım 6, 3 resimden 2. How to Remove a Broken and Embedded Screw: adım 6, 3 resimden 3.
    • Using a wrench, unscrew the extractor.
    • The screw will come along with it, freeing the hole.
    FixBot'a Sor
    Yorum Ekle
  7. How to Remove a Broken and Embedded Screw: adım 7, 2 resimden 1. How to Remove a Broken and Embedded Screw: adım 7, 2 resimden 2.
    • Screw the new screw inside the freed hole.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
It all sounds great, but... It didn't work. I have a Porter-Cable older router. The first screw in the base came out without a problem, and the other 2 screws wouldn't budge. I tried various penetrating oils and nothing. I drilled one of the screws and tried an extractor...nothing. I cut off the screw and drilled clean through, then tried the extractor again...nothing. So, what's left of the screw is drilled out, won't budge with a hole, and is laughing at me.
Although I haven't tried it yet, I was going to cut of the base, leaving the screw intact, getting some vise grips and try to twist it out.
Any other ideas??
frustrated home improvement - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 108
Son 30 gün: 534
Her zaman: 20,661
