Ana içeriğe geç
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
Neye ihtiyacın var
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 1, 2 resimden 1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 1, 2 resimden 2.
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 2, 3 resimden 1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 2, 3 resimden 2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 2, 3 resimden 3.
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 3, 1 resimden 1.
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 4, 2 resimden 1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 4, 2 resimden 2.
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 5, 1 resimden 1.
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 6, 3 resimden 1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 6, 3 resimden 2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 6, 3 resimden 3.
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 7, 2 resimden 1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 7, 2 resimden 2.
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): adım 8, 1 resimden 1.
    • Insert a paper clip and turn until the clog is removed.
Sonuç
Hector Vazquez
157 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 541
