Ana içeriğe geç
How to Remove a Label From a Glass Jar
Neye ihtiyacın var
  1. How to Remove a Label From a Glass Jar, How to Remove a Label From a Glass Jar: adım 1, 1 resimden 1.
    • Boil enough water to fill both glass jars.
    • Pour the boiling water into the smaller jar using a tea kettle.
    • The hot water will heat up the glass and melt the adhesive from the inside.
  2. How to Remove a Label From a Glass Jar: adım 2, 2 resimden 1. How to Remove a Label From a Glass Jar: adım 2, 2 resimden 2.
    • Place the lid onto the jar and tighten.
    • This step is optional if the larger container in Step 3 has a lid.
  3. How to Remove a Label From a Glass Jar: adım 3, 2 resimden 1. How to Remove a Label From a Glass Jar: adım 3, 2 resimden 2.
    • Place the jar into a larger glass container.
  4. How to Remove a Label From a Glass Jar: adım 4, 1 resimden 1.
    • Pour hot water into the larger jar until the water level is above the label.
  5. How to Remove a Label From a Glass Jar: adım 5, 1 resimden 1.
    • Add a few drops of dish soap into the larger jar.
    • This helps to clean up residue from the label.
  6. How to Remove a Label From a Glass Jar: adım 6, 2 resimden 1. How to Remove a Label From a Glass Jar: adım 6, 2 resimden 2.
    • Place the lid on the larger container and tighten.
    • This prevents heat from leaving the container.
    • Let the container sit for 10 to 15 minutes or until completely cooled.
  7. How to Remove a Label From a Glass Jar: adım 7, 2 resimden 1. How to Remove a Label From a Glass Jar: adım 7, 2 resimden 2.
    • Remove the smaller jar from the larger container.
    • Pour the water out of the jar.
    • Peel the label off of the jar.
    • For containers with loose labels, the label will fall off or be able to be slipped off.
    • Wipe off excess residue with a cloth or paper towel.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Ridhwan Hasnat
235 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Génial ! Je n'y avais jamais pensé. Merci beaucoup !
Josette Léost - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 829
