Ana içeriğe geç
How to Remove scratches from a CD
Neye ihtiyacın var
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: adım 1, 1 resimden 1.
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
    FixBot'a Sor
    Yorum Ekle
  2. How to Remove scratches from a CD: adım 2, 2 resimden 1. How to Remove scratches from a CD: adım 2, 2 resimden 2.
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
    FixBot'a Sor
    Yorum Ekle
  3. How to Remove scratches from a CD: adım 3, 1 resimden 1.
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
    FixBot'a Sor
    Yorum Ekle
  4. How to Remove scratches from a CD: adım 4, 3 resimden 1. How to Remove scratches from a CD: adım 4, 3 resimden 2. How to Remove scratches from a CD: adım 4, 3 resimden 3.
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
    FixBot'a Sor
    Yorum Ekle
  5. How to Remove scratches from a CD: adım 5, 1 resimden 1.
    • Let the CD sit for 2 to 3 minutes.
    FixBot'a Sor
    Yorum Ekle
  6. How to Remove scratches from a CD: adım 6, 1 resimden 1.
    • Rinse off the toothpaste with lukewarm water.
    FixBot'a Sor
    Yorum Ekle
  7. How to Remove scratches from a CD: adım 7, 1 resimden 1.
    • Let the CD air dry, or dry with a non-linen towel.
    FixBot'a Sor
    Yorum Ekle
  8. How to Remove scratches from a CD: adım 8, 1 resimden 1.
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
    FixBot'a Sor
    Yorum Ekle
Sonuç
52 farklı kişi bu kılavuzu tamamladı.
Nick Jones
1.677 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G4
5 Üyeler
17 adet Kılavuz yazıldı
5Kılavuz Yorumları
Works great!
Paul Johnson - Yanıt Paylaş
thank youuuuuuuuu
aboabdo.2007 - Yanıt Paylaş
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - Yanıt Paylaş
It did not work for me
Leisy Madrigal - Yanıt Paylaş
Me Funciono muy bien, gracias!
Esteban Montero - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 61
Son 7 gün: 431
Son 30 gün: 1,716
Her zaman: 95,058
