Ana içeriğe geç
How to Remove scratches from a CD
Neye ihtiyacın var
  1. How to Remove scratches from a CD, How to Remove scratches from a CD: adım 1, 1 resimden 1.
    • Identify any scratches.
    • Some scratches may be too deep to be removed. In this case, this method may not work.
  2. How to Remove scratches from a CD: adım 2, 2 resimden 1. How to Remove scratches from a CD: adım 2, 2 resimden 2.
    • Take the CD to the sink.
    • Wash with lukewarm water to remove any dust or dirt.
  3. How to Remove scratches from a CD: adım 3, 1 resimden 1.
    • Let the CD air dry, or dry with towel.
    • Use a non-linen towel or your CD will need to be washed again.
  4. How to Remove scratches from a CD: adım 4, 3 resimden 1. How to Remove scratches from a CD: adım 4, 3 resimden 2. How to Remove scratches from a CD: adım 4, 3 resimden 3.
    • Take the toothpaste, and apply it to your index finger.
    • Rinse the toothpaste in lukewarm water and apply to the CD.
    • Rub toothpaste in a circular motion from the center to the outer edge.
    • Add multiple layers of toothpaste to cover all of the scratches.
    • Use a white toothpaste, not a gel. Gels containing little beads may cause more damage to the CD.
  5. How to Remove scratches from a CD: adım 5, 1 resimden 1.
    • Let the CD sit for 2 to 3 minutes.
    Unless I’m missing something, If you’re using toothpaste to polish the scratches out of a CD, there’s no need to let it sit with the paste on it. It’s the circular motion moving the aggregate in the paste that is removing the scratches.
    Jimmy Hoffa - Yanıt
  6. How to Remove scratches from a CD: adım 6, 1 resimden 1.
    • Rinse off the toothpaste with lukewarm water.
  7. How to Remove scratches from a CD: adım 7, 1 resimden 1.
    • Let the CD air dry, or dry with a non-linen towel.
  8. How to Remove scratches from a CD: adım 8, 1 resimden 1.
    • Inspect your disk.
    • If your disk still has scratches, repeat the process.
    • You could also try to burn the disk onto another disk if the disk is lagging.
Sonuç
40 farklı kişi bu kılavuzu tamamladı.
Nick Jones
1.389 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 üyesi
CPSU-GREEN-F15S14G4
5 Üyeler
16 adet Kılavuz yazıldı
5 Yorum
thank youuuuuuuuu
aboabdo.2007 - Yanıt
Funziona anche con i DVD di film e videogiochi questo procedimento? Oppure è solo specifico per i CD?
Francesco Pepe - Yanıt
It did not work for me
Leisy Madrigal - Yanıt
Me Funciono muy bien, gracias!
Esteban Montero - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 41
Son 7 gün: 263
Son 30 gün: 1,168
Her zaman: 56,983
