Ana içeriğe geç
How to Remove the Back Plate of a TI-NSpire
Neye ihtiyacın var
  1. How to Remove the Back Plate of a TI-NSpire, How to Remove the Back Plate of a TI-NSpire: adım 1, 1 resimden 1.
    • Place the calculator screen facing down, with the back plate facing up.
  2. How to Remove the Back Plate of a TI-NSpire: adım 2, 1 resimden 1.
    • Remove the six 7.3 mm screws from the back of the calculator using a Phillips #000 screwdriver.
  3. How to Remove the Back Plate of a TI-NSpire: adım 3, 3 resimden 1. How to Remove the Back Plate of a TI-NSpire: adım 3, 3 resimden 2. How to Remove the Back Plate of a TI-NSpire: adım 3, 3 resimden 3.
    • Slide the latch to the right to release the keypad.
    • Pull the keypad down at the same time.
  4. How to Remove the Back Plate of a TI-NSpire: adım 4, 1 resimden 1.
    • Remove the screw near the bottom of the calculator on the front side.
    • The screw is behind where the keyboard normally sits.
  5. How to Remove the Back Plate of a TI-NSpire: adım 5, 3 resimden 1. How to Remove the Back Plate of a TI-NSpire: adım 5, 3 resimden 2. How to Remove the Back Plate of a TI-NSpire: adım 5, 3 resimden 3.
    • Turn the calculator over so the back plate faces up.
    • Use the iFixit Opening Tool to carefully pry the back plate out at the bottom right corner.
    • The prying order is arbitrary. The importance is to pry across the length of the calculator.
    • Repeat the prying step on the middle right side, moving along the perimeter of the calculator.
    • Repeat the prying step on the top right corner.
  6. How to Remove the Back Plate of a TI-NSpire: adım 6, 1 resimden 1.
    • Use your hands to manually separate the now loosened back plate from the calculator.
Sonuç
To reassemble your device, carefully push the back plate back onto the calculator. Then replace the screws back into the back plate.
Bir başkası bu kılavuzu tamamladı.
John Baek
31 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-52, Forte Fall 2012 Cal Poly, Team 7-52, Forte Fall 2012 üyesi
CPSU-FORTE-F12S7G52
5 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 21
Her zaman: 4,607
