Ana içeriğe geç
How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus
Neye ihtiyacın var
  1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Heat the back cover: adım 1, 1 resimden 1.
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: adım 2, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: adım 2, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 3, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 3, 2 resimden 2.
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 4, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 4, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 4, 3 resimden 3.
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 5, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 5, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 5, 3 resimden 3.
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 6, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 6, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 6, 3 resimden 3.
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
  7. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the back cover: adım 7, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the back cover: adım 7, 2 resimden 2.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 8, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 8, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: adım 8, 3 resimden 3.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Be careful of the cable that runs beneath the charging coil. Work slowly and stop sliding the pick if it catches on the cable.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 9, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 9, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: adım 9, 3 resimden 3.
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the charging coil: adım 10, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the charging coil: adım 10, 2 resimden 2.
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the NFC antenna: adım 11, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the NFC antenna: adım 11, 2 resimden 2.
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Unfasten the NFC antenna & charging coil assembly screws: adım 12, 1 resimden 1.
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: adım 13, 3 resimden 3.
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the battery cable: adım 14, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the battery cable: adım 14, 2 resimden 2.
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Unfasten the loudspeaker assembly screws: adım 15, 1 resimden 1.
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the loudspeaker assembly.
  16. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Pry up the loudspeaker assembly: adım 16, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Pry up the loudspeaker assembly: adım 16, 2 resimden 2.
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your opening pick to pry up the loudspeaker assembly by tilting it downwards.
  17. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the loudspeaker assembly: adım 17, 2 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the loudspeaker assembly: adım 17, 2 resimden 2.
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  18. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: adım 18, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: adım 18, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: adım 18, 3 resimden 3.
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
  19. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the main flex cable: adım 19, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the main flex cable: adım 19, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the main flex cable: adım 19, 3 resimden 3.
    • Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the main flex cable.
  20. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the interconnect flex cable: adım 20, 3 resimden 1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the interconnect flex cable: adım 20, 3 resimden 2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the interconnect flex cable: adım 20, 3 resimden 3.
    • Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
Sonuç
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
202.516 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.718 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 456
