Ana içeriğe geç
How to Repair A Broken Hip In A Plastic Doll
Neye ihtiyacın var
  1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: adım 1, 2 resimden 1. How to Repair A Broken Hip In A Plastic Doll, How to Repair A Broken Hip In A Plastic Doll: adım 1, 2 resimden 2.
    • Determine where your doll is broken: is it at the knee? Hip? Arm?
    • If it’s broken at the knee, as marked in the second photo, unfortunately this guide will not help as it is a different kind of joint.
  2. How to Repair A Broken Hip In A Plastic Doll: adım 2, 2 resimden 1. How to Repair A Broken Hip In A Plastic Doll: adım 2, 2 resimden 2.
    • If the ball is still inside the leg, remove it with pliers.
  3. How to Repair A Broken Hip In A Plastic Doll: adım 3, 1 resimden 1.
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter.
    • Do not leave fire unattended. The metal will be hot, so please don't touch it with your bare skin.
  4. How to Repair A Broken Hip In A Plastic Doll: adım 4, 1 resimden 1.
    • With the hot sewing needle, make a small hole in the center of the broken off ball. Make sure the needle is straight.
    • This may take a few attempts and a few needles.
    • Heating up the plastic will result in some fumes. Perform this step in a well ventilated area.
  5. How to Repair A Broken Hip In A Plastic Doll: adım 5, 1 resimden 1.
    • Hold one of the sewing pins with the pliers and heat the sewing pin with a lighter. (This is a repeat of Step 3.)
  6. How to Repair A Broken Hip In A Plastic Doll: adım 6, 2 resimden 1. How to Repair A Broken Hip In A Plastic Doll: adım 6, 2 resimden 2.
    • With the hot sewing needle, make a small hole in the peg of the hip. Make sure the needle is straight. Leave the pin inside.
  7. How to Repair A Broken Hip In A Plastic Doll: adım 7, 2 resimden 1. How to Repair A Broken Hip In A Plastic Doll: adım 7, 2 resimden 2.
    • Remove the pin from the broken off ball joint with a pair of pliers.
  8. How to Repair A Broken Hip In A Plastic Doll: adım 8, 2 resimden 1. How to Repair A Broken Hip In A Plastic Doll: adım 8, 2 resimden 2.
    • Using the pliers, cut the pin in the hip section to the appropriate length to fit into the hole made from Step 6.
    • Test the needle length by fitting the ball joint pieces together. The needle should be completely covered.
    • The needle will go flying when you cut it, so direct it away from your face and other precious objects.
  9. How to Repair A Broken Hip In A Plastic Doll: adım 9, 1 resimden 1.
    • Optional: remove any excess burnt plastic from the ball joint.
  10. How to Repair A Broken Hip In A Plastic Doll: adım 10, 3 resimden 1. How to Repair A Broken Hip In A Plastic Doll: adım 10, 3 resimden 2. How to Repair A Broken Hip In A Plastic Doll: adım 10, 3 resimden 3.
    • Remove the pin from the hip and apply super glue to the end.
    • Insert the pin back into the hole.
    • When you reinsert the pin, some glue may come out. Leave it for Step 11.
  11. How to Repair A Broken Hip In A Plastic Doll: adım 11, 1 resimden 1.
    • Push the ball onto the pin. Press together for 1 minute to set the glue.
    • The glue will set in 1 minute but it will take 24 hours to fully cure.
  12. How to Repair A Broken Hip In A Plastic Doll: adım 12, 1 resimden 1.
    • Apply glue around the seam for extra reinforcement.
  13. How to Repair A Broken Hip In A Plastic Doll: adım 13, 2 resimden 1. How to Repair A Broken Hip In A Plastic Doll: adım 13, 2 resimden 2.
    • Now with the ball joint secured into the pelvis, carefully pop the leg back into the hip.
    • The doll's leg should now move as normal!
Sonuç
To reassemble your device, follow these instructions in order.
2 farklı kişi bu kılavuzu tamamladı.
Lee Brunkhardt
232 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-1, Andersen Winter 2023 UC Davis, Team 3-1, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S3G1
5 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 26
Son 30 gün: 104
Her zaman: 1,455
