Ana içeriğe geç
How to Fix an Armhole Gape
Neye ihtiyacın var
  1. How to Fix an Armhole Gape, How to Fix an Armhole Gape: adım 1, 1 resimden 1.
    • Gather the supplies needed.
  2. How to Fix an Armhole Gape: adım 2, 2 resimden 1. How to Fix an Armhole Gape: adım 2, 2 resimden 2.
    • Grab your measuring tape.
    • Measure from the middle of the breast to the under arm part.
  3. How to Fix an Armhole Gape: adım 3, 3 resimden 1. How to Fix an Armhole Gape: adım 3, 3 resimden 2. How to Fix an Armhole Gape: adım 3, 3 resimden 3.
    • Mark the middle of the breast and at the end where the under arm is. (Slide one and two)
    • Mark how big you want to close the gape. (Depends on how big your armhole gape is) (Slide three)
    • Mine was about 0.5 inches. (Slide three)
  4. How to Fix an Armhole Gape: adım 4, 3 resimden 1. How to Fix an Armhole Gape: adım 4, 3 resimden 2. How to Fix an Armhole Gape: adım 4, 3 resimden 3.
    • Connect both of the dots from the breast to the two dots you marked near the underarm.
    • Fold the second line you created and pin them to keep it coming from getting undone. (Slides two and three)
  5. How to Fix an Armhole Gape: adım 5, 1 resimden 1.
    • Sew across.
    • I used a straight sew stitch by hand (you can use a sewing machine and any stitch)
  6. How to Fix an Armhole Gape: adım 6, 1 resimden 1.
    • Lastly, cut the access off.
    • Then flip it inside out.
    • And your done!
Sonuç
Thank you for taking the time to read this.
Danielle Fontanos
133 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-6, Kershman Fall 2023 CSU Los Angeles, Team 5-6, Kershman Fall 2023 üyesi
CSULA-KERSHMAN-F23S5G6
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 17
Her zaman: 341
