Ana içeriğe geç
How to Repair Broken Concrete Steps
Neye ihtiyacın var
  1. How to Repair Broken Concrete Steps, How to Repair Broken Concrete Steps: adım 1, 1 resimden 1.
    • Remove any excess tiles from the staircase that need repair.
    • Make sure to apply rough grip gloves and eye-protection.
  2. How to Repair Broken Concrete Steps: adım 2, 1 resimden 1.
    • Use a claw hammer and chisel to flatten/smooth the surface of concrete to reduce any unsound or flaking stones.
    • Be sure to hammer and chisel within the flat surface; don't dig too deep into the stairs.
  3. How to Repair Broken Concrete Steps: adım 3, 1 resimden 1.
    • Apply a wet, stiff bristle brush to remove dusted concrete.
    • Firmly and aggressively press against the brush onto the concrete, to ensure all flakes are absent.
    • Make sure to leave no holes or corners untouched before moving onto the next step.
  4. How to Repair Broken Concrete Steps: adım 4, 1 resimden 1.
    • Insert the larger chisel into the bucket of the quick-setting cement, in the motion of mixing.
    • The amount of cement should cover 1/3rd of the chisel before reapplying.
  5. How to Repair Broken Concrete Steps: adım 5, 1 resimden 1.
    • Slowly smear the quick-setting cement onto the surface of the smooth concrete.
    • Use one of the faces of the chisel to press against the concrete with paste.
  6. How to Repair Broken Concrete Steps: adım 6, 1 resimden 1.
    • Using a margin trowel, press firmly towards the quick-setting cement to flatten the concrete from a left-to-right motion each time.
    • Pressing firmly and slowly will result in a more professional look.
  7. How to Repair Broken Concrete Steps: adım 7, 1 resimden 1.
    • After applying the quick-setting cement, reapply your tiles and wait 5-7 hours before hardening.
    • If no tiles are needed for your staircase, wait 5 minutes when surface becomes firm to mold and shape the concrete.
Sonuç
By completing these easy steps on repairing concrete steps, you’re finishing repair will provide a pleasing look and safety for the environment.
3 farklı kişi bu kılavuzu tamamladı.
Barvee
226 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Thanks for the repair pointers!
Nikki Mcmullen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 1,679
