Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Remove any excess tiles from the staircase that need repair.
Use a claw hammer and chisel to flatten/smooth the surface of concrete to reduce any unsound or flaking stones.
Apply a wet, stiff bristle brush to remove dusted concrete.
Firmly and aggressively press against the brush onto the concrete, to ensure all flakes are absent.
Insert the larger chisel into the bucket of the quick-setting cement, in the motion of mixing.
Slowly smear the quick-setting cement onto the surface of the smooth concrete.
Use one of the faces of the chisel to press against the concrete with paste.
Using a margin trowel, press firmly towards the quick-setting cement to flatten the concrete from a left-to-right motion each time.
After applying the quick-setting cement, reapply your tiles and wait 5-7 hours before hardening.
If no tiles are needed for your staircase, wait 5 minutes when surface becomes firm to mold and shape the concrete.
2 farklı kişi bu kılavuzu tamamladı.
