Ana içeriğe geç
How to Repair Bumped Corners on a Hardcover Book
Neye ihtiyacın var
  1. How to Repair Bumped Corners on a Hardcover Book, How to Repair Bumped Corners on a Hardcover Book: adım 1, 1 resimden 1.
    • Open the book to one cover corner.
    • Apply the PVA glue on a bumped corner using the glue tip or a small paintbrush.
    • Coat the worn layers with the same paintbrush.
    • The corner layers should be well-saturated for them to stick together.
  2. How to Repair Bumped Corners on a Hardcover Book: adım 2, 1 resimden 1.
    • Pinch the corner layers together with a piece of cloth.
    • Remove excess glue with paper towels or a cloth rag.
    • Pinching the corner layers will help them stick together with the glue.
    • The cloth will provide minimal mess and remove excess glue.
  3. How to Repair Bumped Corners on a Hardcover Book: adım 3, 1 resimden 1.
    • Wrap the entire corner with a small sheet of wax paper.
    • The wax paper will protect the work done on the corner for the next steps.
  4. How to Repair Bumped Corners on a Hardcover Book: adım 4, 1 resimden 1.
    • Put one piece of wood chipboard on each side of the corner.
    • The wood chipboard will prevent the book corner from denting in the next step.
  5. How to Repair Bumped Corners on a Hardcover Book: adım 5, 1 resimden 1.
    • Clamp everything together.
    • Let everything dry for 30 minutes.
    • This book-binding method ensures enough time and support for the bumped corner to transform into better condition.
  6. How to Repair Bumped Corners on a Hardcover Book: adım 6, 2 resimden 1. How to Repair Bumped Corners on a Hardcover Book: adım 6, 2 resimden 2.
    • Remove the clip, boards, and wax paper to see the results.
    • Repeat steps 1-6 for any other bumped book corner(s).
Sonuç
And that's bookbinding! Enjoy your book in new condition.
2 farklı kişi bu kılavuzu tamamladı.
Salimah Rogers
160 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 3-6, Whithaus Spring 2024 UC Davis, Team 3-6, Whithaus Spring 2024 üyesi
UCD-WHITHAUS-S24S3G6
3 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 24
Son 30 gün: 63
Her zaman: 162
