Ana içeriğe geç
How to Repair Cracks in T-Shirt Print
Neye ihtiyacın var
  1. How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: adım 1, 3 resimden 1. How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: adım 1, 3 resimden 2. How to Repair Cracks in T-Shirt Print, How to Repair Cracks in T-Shirt Print: adım 1, 3 resimden 3.
    • Lay your shirt on a flat surface.
    • Use scissors to cut a piece of parchment paper the same size as the design on your shirt.
    • Insert the piece of parchment paper inside of the shirt and under the design.
    • This is to prevent the acetone from staining.
  2. How to Repair Cracks in T-Shirt Print: adım 2, 3 resimden 1. How to Repair Cracks in T-Shirt Print: adım 2, 3 resimden 2. How to Repair Cracks in T-Shirt Print: adım 2, 3 resimden 3.
    • Dampen a cotton ball with the acetone.
    • Gently dab the cotton ball onto the cracked area of the shirt and hold it in place for 1 minute.
    • Remember to always dab, do not rub.
    • Repeat this over the whole area that you wish to restore.
    • Let your shirt set for 3-5 minutes
    • If you're doing a small area, let it set for 2-3 minutes. If it is any bigger, set it for 5 minutes.
  3. How to Repair Cracks in T-Shirt Print: adım 3, 3 resimden 1. How to Repair Cracks in T-Shirt Print: adım 3, 3 resimden 2. How to Repair Cracks in T-Shirt Print: adım 3, 3 resimden 3.
    • Cut a piece of parchment paper to match the size of the shirt's design, then place it over the design.
    • Turn on a clothes iron to the highest heat setting with NO steam.
    • Be careful when handling the iron, it gets burning hot!
    • When your iron is ready, place it over the parchment paper and go over the whole design once.
    • Go over the areas that had the cracks for at least 10-15 seconds.
  4. How to Repair Cracks in T-Shirt Print: adım 4, 1 resimden 1.
    • Now your shirt design should no longer have cracks.
Bitiş Çizgisi
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 58
Son 30 gün: 321
Her zaman: 2,691
